Debugging an RTEMS Application, show threads in gdb possible
Matthias Goldhoorn
matthias.goldhoorn at uni-bremen.de
Wed Nov 14 10:27:32 UTC 2012
On 12.11.2012 12:29, Sebastian Huber wrote:
> Hello,
> I cannot say much to the GDB support since I mainly use the Lauterbach
> debugger, but there is some GDB support mentioned here:
> http://www.rtems.org/wiki/index.php/GDB_Python
> You can also start the RTEMS shell and use the "task", "sema",
> "cpuuse", etc. commands to figure out the system state.
Hi Again,
i got these scripts running.
I got output like:
(gdb) rtems_posix_threads
# | Name | ID | Pri | Nsecs | State
1 | | 0b010001 | 253 | 921902273 | DELAY
2 | | 0b010002 | 253 | 23244932 | DORM Wbuf
3 | | 0b010003 | 253 | 848975 | Wcvar
4 | | 0b010004 | 253 | 475098 | Wsem
5 | | 0b010005 | 253 | 10752105 | DELAY
6 | | 0b010006 | 253 | 717069 | Wsem
7 | | 0b010007 | 254 | 768276 | Wcvar
8 | | 0b010008 | 253 | 44815995 | SUSP TRANS
the detailed function seems not to work:
(gdb) rtems_posix_thread 2
BACKTRACE
I don't see any Backtrace here, only the word "BACKTRACE" there is one
additional helper funtion:
rtems_task_backtrack
which requires arg0 = pointer to the Thread_Control_struct of the task.
which i don't have.
The standard console gives me similar output (and for reasons i
currently don’t understand stop's my program, but whatever).
How are you guys debugging thinks like this. My Application simply hangs
i need the backtrace of the current threads to get into this...
One Thread is anywhere blocked, don't know if i get an deadlock or
something else, is there no way to get the backtraces of all running
threads in rtems?
Greetings,
Matthias
Dipl.-Inf. Matthias Goldhoorn
Space and Underwater Robotic
Universität Bremen
FB 3 - Mathematik und Informatik
AG Robotik
Robert-Hooke-Straße 5
28359 Bremen, Germany
Tel.: +49 421 178 45-4193
Zentrale: +49 421 178 45-6550
Fax: +49 421 178 45-4150
E-Mail: matthias.goldhoorn at uni-bremen.de
Weitere Informationen: http://www.informatik.uni-bremen.de/robotik
