NFS in a critical realtime system
Jonathan Kalbfeld
jonathan.kalbfeld at gmail.com
Tue Nov 13 00:14:56 UTC 2012
Just from a systems perspective, you may want to weigh the relative
benefits of using UDP versus TCP for your NFS transport layer.
On Mon, Nov 12, 2012 at 2:21 PM, rwas <rbtwas at gmail.com> wrote:
> I'm being pressed to use NFS in a our realtime system. We are running
> are primary high priority task at 1khz and at least half of our cycle to
> cycle
> time budget is used in it. It was intended that NFS be used for high rate
> data logging.
> I am actually quite reluctant to use NFS in our system (over a dedicated
> rpc, or
> socket io logging server).
> Any thoughts?
> Robert W.
> ______________________________**_________________
> rtems-users mailing list
> rtems-users at rtems.org
> http://www.rtems.org/mailman/**listinfo/rtems-users<http://www.rtems.org/mailman/listinfo/rtems-users>
Jonathan Kalbfeld
V: +1 212 518 2441
F: +1 818 495 2140
URL: <http://lists.rtems.org/pipermail/users/attachments/20121112/66a82f14/attachment-0001.html>
