RTEMS.info IP Change Complete
Ralf Corsepius ralf.corsepius at rtems.org
Wed Oct 10 09:18:30 UTC 2012
On 10/10/2012 09:14 AM, Ralf Corsepius wrote:
> ATM, I have re-enabled rtems.info, but ... I will likely re-disable it
> again, because of OAR's DNS behavior, which causes the mirrorlist
> checker to switch on and off rtems.info inside of the mirrorlists.
After some more experiments, I took off rtems.info from the mirrorlist,
again.
Ralf
