configuring RTEMS target optimization levels
Mick Davis mickd at goanna.iinet.net.au
Wed Sep 12 13:07:02 UTC 2012
I can describe what I do and hope that it answers your question.
In the source tree c/src/lib/libbsp/<cpu>/<bsp>/make/custom/<bsp>.cfg I have
CPU_CFLAGS = -mcpu=arm926ej-s  -g
and
CFLAGS_OPTIMIZE_V = -O3
When the rtems libs are built they're optimised. There's no easy way I
know of to get non-optimised rtems libs.
I build apps using as a template the rtems makefiles that get installed,
eg installed as make/Templates/Makefile.leaf .
I use the ordinary 'make' to get an optimised app build, which uses the
CFLAGS_OPTIMIZE_V flags.
Or I 'make debug' to get a non-optimised build, where CPU_CFLAGS are
still used but CFLAGS_OPTIMIZE_V are not.
HTH
On 12/09/12 08:35, Hill, Jeff wrote:
> Hello All,
> Please forgive a nebie question.
> Currently I configure the rtems/rtems-bsp target build by
> manually setting the following variables. Is this the correct way
> to set the optimization level with the gnu build system; I was
> unable to find anything in the configure help, but wonder if
> the default optimization level shouldn't be configured based
> on the cpu architecture?
> export CXXFLAGS_FOR_TARGET="-g -O3 -mhw-mul -mhw-div"
> export CFLAGS_FOR_TARGET="-g -O3 -mhw-mul -mhw-div"
> I know now that the following options are for configuring
> the application build, and have nothing to do with
> the gnu rtems/rtems-bsp build.
> RTEMS_VARIANT=OPTIMIZE
> #RTEMS_VARIANT=PROFILE
> #RTEMS_VARIANT=DEBUG
> Furthermore I think I know now that the <BSP>/make/custom/<BSP>.cfg
> file configures the application build based on the above options, but
> has no impact whatsoever on the gnu rtems/rtems-bsp build.
> Jeff
> rtems-users mailing list
> rtems-users at rtems.org
Mick Davis
Goanna Technologies Pty Ltd
+61 8 9444 2634
