RES: passing parameters to task
Luca Cinquepalmi
cinquepalmi at planetek.it
Mon Sep 17 13:18:26 UTC 2012
Thank you Wendell, that's exactly what I mean. I have two question for you.
1)* In
*rtems_task mytask(rtems_task_argument arg)*
* struct complex_task_parameters* p;*
* p = (complex_task_parameters *)arg;*
* while(true)*
* //use parameters in p*
I have a type error in *p = (complex_task_parameters *)arg;
*Is complex_task_parameters type correct?
*2)* How can I use parameters in while cycle? How can I refer to "foo"
for example?
Thanks a lot again!
Luca
Il 17/09/2012 14.35, Wendell Pereira da Silva ha scritto:
> Hi Luca,
> Mathew, please, may I post an example?
> rtems_task mytask(rtems_task_argument arg);
> uint32_t ui; // first parameter...
> uint16_t usi; // second parameter...
> const char* foo; // another parameter...
> rtems_task Init(rtems_task_argument arg)
> rtems_id tid;
> struct complex_task_parameters* p_task_param;
> // allocate and initialize parameters
> p_task_param = calloc(1, sizeof(*p_task_param));
> p_task_param->ui = 1;
> p_task_param->usi = 0x1000;
> p_task_param->foo = "test...";
> // create the task as usual
> rtems_task_create(..., &tid);
> // now pass the parameter to the task;
> // use typecast to make the compiler happy.
> rtems_task_start(tid, mytask, (rtems_task_argument)p_task_param);
> while(true)
> Hope it helps.
> --Wendell.
> *De:*rtems-users-bounces at rtems.org
> [mailto:rtems-users-bounces at rtems.org] *Em nome de *Luca Cinquepalmi
> *Enviada em:* segunda-feira, 17 de setembro de 2012 07:20
> *Para:* Mathew Benson
> *Cc:* rtems-users at rtems.org
> *Assunto:* Re: passing parameters to task
> I understand your suggestion... is there any example I could view?
> Luca
> Il 17/09/2012 12.18, Mathew Benson ha scritto:
> The same way you would with a POSIX pthread create call. Just
> malloc a struct with your multiple parameters, set your
> parameters, and pass the reference of your struct to the function.
> In your task entry point, cast the argument to a pointer to your
> struct and pull your parameters out.
> Sent from my Amiga 1000
> On Sep 17, 2012, at 4:35 AM, Luca Cinquepalmi
> <cinquepalmi at planetek.it <mailto:cinquepalmi at planetek.it>> wrote:
> Hi all,
> I would like to know if is it possible to pass more than one
> argument to a single task...
> At the moment I only use this syntax when I define a task
> *rtems_task Test_task(rtems_task_argument unused)*
> How can I declare and define a more parameters dependent task?
> Thanks a lot.
> Luca
> rtems-users mailing list
> rtems-users at rtems.org <mailto:rtems-users at rtems.org>
URL: <http://lists.rtems.org/pipermail/users/attachments/20120917/7bad0b4e/attachment.html>
