RES: RES: passing parameters to task
Wendell Pereira da Silva
wendell.silva at compsisnet.com.br
Mon Sep 17 13:54:14 UTC 2012
Oh.. .sorry..
1) Change to (struct complex_task_parameters *)
2) Use it as a member of structure dynamically allocated (by means of -> operator). Example:
printk(“foo = %s\n, p->foo);
--Wendell.
De: Luca Cinquepalmi [mailto:cinquepalmi at planetek.it]
Enviada em: segunda-feira, 17 de setembro de 2012 10:18
Para: Wendell Pereira da Silva
Cc: Mathew Benson; rtems-users at rtems.org
Assunto: Re: RES: passing parameters to task
Thank you Wendell, that's exactly what I mean. I have two question for you.
1) In
rtems_task mytask(rtems_task_argument arg)
struct complex_task_parameters* p;
p = (complex_task_parameters *)arg;
while(true)
//use parameters in p
I have a type error in p = (complex_task_parameters *)arg;
Is complex_task_parameters type correct?
2) How can I use parameters in while cycle? How can I refer to "foo" for example?
Thanks a lot again!
Luca
Il 17/09/2012 14.35, Wendell Pereira da Silva ha scritto:
Hi Luca,
Mathew, please, may I post an example?
rtems_task mytask(rtems_task_argument arg);
uint32_t ui; // first parameter...
uint16_t usi; // second parameter...
const char* foo; // another parameter...
rtems_task Init(rtems_task_argument arg)
rtems_id tid;
struct complex_task_parameters* p_task_param;
// allocate and initialize parameters
p_task_param = calloc(1, sizeof(*p_task_param));
p_task_param->ui = 1;
p_task_param->usi = 0x1000;
p_task_param->foo = "test...";
// create the task as usual
rtems_task_create(..., &tid);
// now pass the parameter to the task;
// use typecast to make the compiler happy.
rtems_task_start(tid, mytask, (rtems_task_argument)p_task_param);
while(true)
Hope it helps.
--Wendell.
De: rtems-users-bounces at rtems.org<mailto:rtems-users-bounces at rtems.org> [mailto:rtems-users-bounces at rtems.org] Em nome de Luca Cinquepalmi
Enviada em: segunda-feira, 17 de setembro de 2012 07:20
Para: Mathew Benson
Cc: rtems-users at rtems.org<mailto:rtems-users at rtems.org>
Assunto: Re: passing parameters to task
I understand your suggestion... is there any example I could view?
Luca
Il 17/09/2012 12.18, Mathew Benson ha scritto:
The same way you would with a POSIX pthread create call. Just malloc a struct with your multiple parameters, set your parameters, and pass the reference of your struct to the function. In your task entry point, cast the argument to a pointer to your struct and pull your parameters out.
Sent from my Amiga 1000
On Sep 17, 2012, at 4:35 AM, Luca Cinquepalmi <cinquepalmi at planetek.it<mailto:cinquepalmi at planetek.it>> wrote:
Hi all,
I would like to know if is it possible to pass more than one argument to a single task...
At the moment I only use this syntax when I define a task
rtems_task Test_task(rtems_task_argument unused)
How can I declare and define a more parameters dependent task?
Thanks a lot.
Luca
rtems-users mailing list
http://www.rtems.org/mailman/listinfo/rtems-users
URL: <http://lists.rtems.org/pipermail/users/attachments/20120917/caf616a6/attachment.html>
