RES: RES: passing parameters to task
Luca Cinquepalmi
cinquepalmi at planetek.it
Mon Sep 17 13:59:33 UTC 2012
Thank you Wendell! You solved all my doubt!:-)
Great!
Luca
Il 17/09/2012 15.54, Wendell Pereira da Silva ha scritto:
> Oh.. .sorry..
> 1)Change to (*struct* complex_task_parameters *)
> 2)Use it as a member of structure dynamically allocated (by means of
> -> operator). Example:
> printk(“foo = %s\n, p->foo);
> --Wendell.
> *De:*Luca Cinquepalmi [mailto:cinquepalmi at planetek.it]
> *Enviada em:* segunda-feira, 17 de setembro de 2012 10:18
> *Para:* Wendell Pereira da Silva
> *Cc:* Mathew Benson; rtems-users at rtems.org
> *Assunto:* Re: RES: passing parameters to task
> Thank you Wendell, that's exactly what I mean. I have two question for
> you.
> 1)* In
> *rtems_task mytask(rtems_task_argument arg)*
> *struct complex_task_parameters* p;*
> *p = (complex_task_parameters *)arg;*
> *while(true)*
> *//use parameters in p*
> I have a type error in *p = (complex_task_parameters *)arg;
> *Is complex_task_parameters type correct?
> *2)* How can I use parameters in while cycle? How can I refer to "foo"
> for example?
> Thanks a lot again!
> Luca
> Il 17/09/2012 14.35, Wendell Pereira da Silva ha scritto:
> Hi Luca,
> Mathew, please, may I post an example?
> rtems_task mytask(rtems_task_argument arg);
> uint32_t ui; // first parameter...
> uint16_t usi; // second parameter...
> const char* foo; // another parameter...
> rtems_task Init(rtems_task_argument arg)
> rtems_id tid;
> struct complex_task_parameters* p_task_param;
> // allocate and initialize parameters
> p_task_param = calloc(1, sizeof(*p_task_param));
> p_task_param->ui = 1;
> p_task_param->usi = 0x1000;
> p_task_param->foo = "test...";
> // create the task as usual
> rtems_task_create(..., &tid);
> // now pass the parameter to the task;
> // use typecast to make the compiler happy.
> rtems_task_start(tid, mytask, (rtems_task_argument)p_task_param);
> while(true)
> Hope it helps.
> --Wendell.
> *De:*rtems-users-bounces at rtems.org
> <mailto:rtems-users-bounces at rtems.org>
> [mailto:rtems-users-bounces at rtems.org] *Em nome de *Luca Cinquepalmi
> *Enviada em:* segunda-feira, 17 de setembro de 2012 07:20
> *Para:* Mathew Benson
> *Cc:* rtems-users at rtems.org <mailto:rtems-users at rtems.org>
> *Assunto:* Re: passing parameters to task
> I understand your suggestion... is there any example I could view?
> Luca
> Il 17/09/2012 12.18, Mathew Benson ha scritto:
> The same way you would with a POSIX pthread create call. Just
> malloc a struct with your multiple parameters, set your
> parameters, and pass the reference of your struct to the
> function. In your task entry point, cast the argument to a
> pointer to your struct and pull your parameters out.
> Sent from my Amiga 1000
> On Sep 17, 2012, at 4:35 AM, Luca Cinquepalmi
> <cinquepalmi at planetek.it <mailto:cinquepalmi at planetek.it>> wrote:
> Hi all,
> I would like to know if is it possible to pass more than
> one argument to a single task...
> At the moment I only use this syntax when I define a task
> *rtems_task Test_task(rtems_task_argument unused)*
> How can I declare and define a more parameters dependent task?
> Thanks a lot.
> Luca
> rtems-users mailing list
URL: <http://lists.rtems.org/pipermail/users/attachments/20120917/96f86978/attachment.html>
