Fwd: Ref: Building RTEMS for sparc/sis fails with "error: no acceptable cc found in $PATH"
Andrei Dimitrief-Jianu
andrei.dimitrief.jianu at gmail.com
Tue Sep 18 14:31:38 UTC 2012
Installing the sparc tools (which were missing) solved the problem. Thank
you Joel!
@Luca: I was not very keen on having the build dumped in the
/opt/rtems-4.10 directory, so I used the working directory instead.
Thank you!
---------- Forwarded message ----------
From: Luca Cinquepalmi <cinquepalmi at planetek.it>
Date: Tue, Sep 18, 2012 at 3:30 AM
Subject: Re: Ref: Building RTEMS for sparc/sis fails with "error: no
To: rtems-users at rtems.org
...and then fix --prefix=/opt/rtems-4.10 in configure command...
Luca
Il 17/09/2012 20.36, Joel Sherrill ha scritto:
> You need to have a sparc-rtems4.10 toolset installed. The other BSPs you
> mentioned were ARM.
> __joel
> Andrei Dimitrief-Jianu <andrei.dimitrief.jianu at gmail.**com<andrei.dimitrief.jianu at gmail.com>>
> wrote:
> Hello,
>> I am trying to build RTEMS 4.10.2 for sparc/sis.
>> The build fails with:
>> configure: WARNING: using cross tools not prefixed with host triplet
>> configure: error: no acceptable cc found in $PATH
>> The CL that I use is:
>> ./../rtems-4.10.2/configure --target=sparc-rtems4.10 --enable-rtemsbsp=sis
>> make all
>> make install
>> Not sure if this helps, but the build works for arm/csb336 and arm/csb337
>> on the same host machine.
>> Thanks.
> ______________________________**_________________
> rtems-users mailing list
> http://www.rtems.org/mailman/**listinfo/rtems-users<http://www.rtems.org/mailman/listinfo/rtems-users>
URL: <http://lists.rtems.org/pipermail/users/attachments/20120918/8d3c6e94/attachment.html>
