Ref: signal queueing when signal processing is disabled
Andrei Dimitrief-Jianu andrei.dimitrief.jianu at gmail.com
Wed Sep 19 20:23:55 UTC 2012
Hello,
I have a question about RTEMS signal queueing:
Let's assume I have a task with signal processing disabled (RTEMS_NO_ASR)
and, while in this state, the task receives multiple signals that have the
same type. When signal processing is enabled, will the task receive one
signal or a signal instance for each signal that is posted?
Thanks!
URL: <http://lists.rtems.org/pipermail/users/attachments/20120919/f37af83a/attachment.html>
