Ref: signal queueing when signal processing is disabled
Wed Sep 19 22:08:53 UTC 2012
Assuming you have installed an ASR handler, then when you enable ASR processing, you will get it once. They are represented as bits.
I hope this is covered in the Users Guide. :)
Andrei Dimitrief-Jianu <andrei.dimitrief.jianu at gmail.com> wrote:
>Hello,
>I have a question about RTEMS signal queueing:
>Let's assume I have a task with signal processing disabled (RTEMS_NO_ASR) and, while in this state, the task receives multiple signals that have the same type. When signal processing is enabled, will the task receive one signal or a signal instance for each signal that is posted?
>Thanks!
