ANN: rtems-4.10 toolchain rpms available for Fedora 18
Ralf Corsepius
ralf.corsepius at rtems.org
Thu Sep 20 12:25:15 UTC 2012
Hi,
I am proud to announce the availability of Fedora-18 toolchain rpm
packages and repositories for RTEMS-4.10.
ftp://ftp.rtems.org/pub/rtems/linux/4.10/fedora/18/
Except of having reflected system particularities of Fedora 18 back to
the rpm-specs, the actual toolchain sources are mostly identical[1] to
those so far having been used for other Linux distros and older Fedora
releases.
Notes:
* Fedora 18 is the next version of Fedora. It has _not_ been released.
It currently is in "alpha-stable" development stages and is not yet
end-user ready.
* Though this repository is supposed to be fully functional and people
should feel free to using be it, it so far is not meant to be used by
end-users.
Ralf
[1] The sources are identical with one exception:
rtems-4.10-bfin-rtems4.10-gdb(-7.3.1) had failed to build from source on
openSUSE. When investigating, the cause had shown to be a general issue
related to the linux kernel on several more distros (Comprising all
Fedoras).
