sparc-rtems4.11-gdb error
Luca Cinquepalmi
cinquepalmi at planetek.it
Tue Sep 4 10:40:12 UTC 2012
Hi all,
I successfully installed rtems-4.11. I'm able to compile C source file
without any problem
but when I run rtems debugger (sparc-rtems4.11-gdb) the following
messages appears:
*'import site' falied; use -v for traceback
Traceback (most recent call last)
File "<string>", line 1, in ?
ImportError: No module named os*
so debugger doesnt'work well. I'm not able to solve this problem
although I'm still researching
any suggestion on the web.
Can you help me? Thanks a lot.
Luca
URL: <http://lists.rtems.org/pipermail/users/attachments/20120904/7312ac1e/attachment-0001.html>
