sparc-rtems4.11-gdb error
Joel Sherrill
Joel.Sherrill at OARcorp.com
Tue Sep 4 11:57:45 UTC 2012
What is the version of the debugger?
Is this an RPM or did you build it yourself? If you build it, then how did you configure?
Luca Cinquepalmi <cinquepalmi at planetek.it> wrote:
Hi all,
I successfully installed rtems-4.11. I'm able to compile C source file without any problem
but when I run rtems debugger (sparc-rtems4.11-gdb) the following messages appears:
'import site' falied; use -v for traceback
Traceback (most recent call last)
File "<string>", line 1, in ?
ImportError: No module named os
so debugger doesnt'work well. I'm not able to solve this problem although I'm still researching
any suggestion on the web.
Can you help me? Thanks a lot.
Luca
URL: <http://lists.rtems.org/pipermail/users/attachments/20120904/88450027/attachment-0001.html>
