sparc-rtems4.11-gdb error
Luca Cinquepalmi cinquepalmi at planetek.it
Tue Sep 4 12:10:05 UTC 2012
Hi Joel,
the debugger version is 7.4.1 and I built it with rpm.
My pyhton version is 2.6.
Shall I build it by myself?
      Luca
Il 04/09/2012 13.57, Joel Sherrill ha scritto:
> What is the version of the debugger?
> Is this an RPM or did you build it yourself? If you build it, then how did you configure?
> Luca Cinquepalmi <cinquepalmi at planetek.it> wrote:
> Hi all,
> I successfully installed rtems-4.11. I'm able to compile C source file
> without any problem
> but when I run rtems debugger (sparc-rtems4.11-gdb) the following
> messages appears:
> *'import site' falied; use -v for traceback
> Traceback (most recent call last)
>     File "<string>", line 1, in ?
> ImportError: No module named os*
> so debugger doesnt'work well. I'm not able to solve this problem
> although I'm still researching
> any suggestion on the web.
> Can you help me? Thanks a lot.
>     Luca
URL: <http://lists.rtems.org/pipermail/users/attachments/20120904/13341477/attachment-0001.html>
