sparc-rtems4.11-gdb error
Luca Cinquepalmi cinquepalmi at planetek.it
Tue Sep 4 13:30:39 UTC 2012
I'm on Ubuntu 10.04 LTS with these RPM installed:
rtems-4.11-sparc-rtems4.11-gdb_7.4.1-2_i386
I didn't install any python RPM... should I?
     Luca
Il 04/09/2012 15.26, Joel Sherrill ha scritto:
> On 09/04/2012 07:10 AM, Luca Cinquepalmi wrote:
>> Hi Joel,
>> the debugger version is 7.4.1 and I built it with rpm.
>> My pyhton version is 2.6.
>> Shall I build it by myself?
> I wasn't suggesting that. Just trying to respond quickly and ask
> for enough details to know whether this was an RPM, a locally
> built binary, etc.
> I am on CentOS 6.3 with these RPMs:
> rtems-4.11-sparc-rtems4.11-gdb-7.4.1-1.el6.i386
> python-2.6.6-29.el6_2.2.i686
> And it works fine. I guess the next question is your host OS
> and how you invoked sparc-rtems4.11-gdb.
> Ralf builds these so if there is some odd dependency not being
> properly met he would know that.
> --joel
>>      Luca
>> Il 04/09/2012 13.57, Joel Sherrill ha scritto:
>>> What is the version of the debugger?
>>> Is this an RPM or did you build it yourself? If you build it, then how did you configure?
>>> Luca Cinquepalmi<cinquepalmi at planetek.it>  wrote:
>>> Hi all,
>>> I successfully installed rtems-4.11. I'm able to compile C source
>>> file without any problem
>>> but when I run rtems debugger (sparc-rtems4.11-gdb) the following
>>> messages appears:
>>> *'import site' falied; use -v for traceback
>>> Traceback (most recent call last)
>>>     File "<string>", line 1, in ?
>>> ImportError: No module named os*
>>> so debugger doesnt'work well. I'm not able to solve this problem
>>> although I'm still researching
>>> any suggestion on the web.
>>> Can you help me? Thanks a lot.
>>>     Luca
> Joel Sherrill, Ph.D.             Director of Research&  Development
> joel.sherrill at OARcorp.com         On-Line Applications Research
>      Support Available             (256) 722-9985
URL: <http://lists.rtems.org/pipermail/users/attachments/20120904/43000865/attachment-0001.html>
