sparc-rtems4.11-gdb error
Joel Sherrill
joel.sherrill at OARcorp.com
Tue Sep 4 13:34:58 UTC 2012
On 09/04/2012 08:30 AM, Luca Cinquepalmi wrote:
> I'm on Ubuntu 10.04 LTS with these RPM installed:
> rtems-4.11-sparc-rtems4.11-gdb_7.4.1-2_i386
> I didn't install any python RPM... should I?
Oh! You converted the RPM to deb or extracted the contents.
That changes things. :)
Try "ldd /opt/rtems-4.11/bin/sparc-rtems4.11-gdb" and see if all
the shared library dependencies are met. That's a starting point.
Hopefully an Ubuntu user will speak up soon. :)
--joel
> Luca
> Il 04/09/2012 15.26, Joel Sherrill ha scritto:
>> On 09/04/2012 07:10 AM, Luca Cinquepalmi wrote:
>>> Hi Joel,
>>> the debugger version is 7.4.1 and I built it with rpm.
>>> My pyhton version is 2.6.
>>> Shall I build it by myself?
>> I wasn't suggesting that. Just trying to respond quickly and ask
>> for enough details to know whether this was an RPM, a locally
>> built binary, etc.
>> I am on CentOS 6.3 with these RPMs:
>> rtems-4.11-sparc-rtems4.11-gdb-7.4.1-1.el6.i386
>> python-2.6.6-29.el6_2.2.i686
>> And it works fine. I guess the next question is your host OS
>> and how you invoked sparc-rtems4.11-gdb.
>> Ralf builds these so if there is some odd dependency not being
>> properly met he would know that.
>> --joel
>>> Luca
>>> Il 04/09/2012 13.57, Joel Sherrill ha scritto:
>>>> What is the version of the debugger?
>>>> Is this an RPM or did you build it yourself? If you build it, then how did you configure?
>>>> Luca Cinquepalmi<cinquepalmi at planetek.it> wrote:
>>>> Hi all,
>>>> I successfully installed rtems-4.11. I'm able to compile C source
>>>> file without any problem
>>>> but when I run rtems debugger (sparc-rtems4.11-gdb) the following
>>>> messages appears:
>>>> *'import site' falied; use -v for traceback
>>>> Traceback (most recent call last)
>>>> File "<string>", line 1, in ?
>>>> ImportError: No module named os*
>>>> so debugger doesnt'work well. I'm not able to solve this problem
>>>> although I'm still researching
>>>> any suggestion on the web.
>>>> Can you help me? Thanks a lot.
>>>> Luca
>> Joel Sherrill, Ph.D. Director of Research& Development
>> joel.sherrill at OARcorp.com On-Line Applications Research
>> Ask me about RTEMS: a free RTOS Huntsville AL 35805
>> Support Available (256) 722-9985
URL: <http://lists.rtems.org/pipermail/users/attachments/20120904/b706fc8f/attachment-0001.html>
