sparc-rtems4.11-gdb error
Ralf Corsepius
ralf.corsepius at rtems.org
Tue Sep 4 14:25:45 UTC 2012
On 09/04/2012 03:53 PM, Joel Sherrill wrote:
> On 09/04/2012 08:44 AM, Luca Cinquepalmi wrote:
>> PS: I used Fedora 14 RPMs
There are no Fedora 14 RPMs.
ftp://ftp.rtems.org/pub/rtems/linux/4.11/fedora/14/i386 is a
symlink to epel5.
It is meant to provide "legacy convenience" for people who could not
affort upgrading to a newer Fedora version, when Fedora 14 went end of
life. Meanwhile Fedora 15 also went out of life, so ... it's due time to
remove the "Fedora 14" legacy symlink ;)
> Checking the dependencies on the rpm on the ftp site,
> the Fedora 14 one is not dependent on Python.
Correct. python support in gdb is disabled in all gdb-rpms, because
cross-gdb's up to 7.4.1 (The shape of 7.5/7.4.9x is yet unknown)
have had a lot of problems with it and because there are unresolved
python related packaging issues.
> You can try "system sparc-rtems4.11-gdb" and see if you
> notice what system call is failing.
> On Ubuntu you may be better off building this.
Good luck ... building gdb is far from being trivial. It's by far the
most complex tool to build of the RTEMS toolchain.
Ralf
