[solved] sparc-rtems4.11-gdb error + gdb question
SAeeD
salpha.2004 at gmail.com
Thu Sep 6 14:51:04 UTC 2012
> What kind of option shall I add in my makefile to compile rtems source
> file in debug mode?
As far as I know, there is no need to change Makefile manually. It is
sufficient to use --enable-rtems-debug while configuring.
On Thu, Sep 6, 2012 at 12:22 PM, Luca Cinquepalmi
<cinquepalmi at planetek.it>wrote:
> I solved my problem. Actually the problem was that I used rtems-gdb RPM.
> I tryed to build it by myself and now I don't have that kind of error.
> I have now another question.
> file in debug mode?
> Only -g in compyling options and links? Shall I add some command in C
> source file?
> Compiled in release mode my software works fine...
> Thanks a lot
> Luca
> Il 04/09/2012 15.59, Luca Cinquepalmi ha scritto:
>> What does this message mean?
>> 'import site' failed; use -v for traceback
>> Traceback (most recent call last):
>> File "/usr/lib/command-not-found", line 10, in <module>
>> import CommandNotFound
>> ImportError: No module named CommandNotFound
>> this is the result of "system" command.
>> Do you have a skype contact?
>> Il 04/09/2012 15.53, Joel Sherrill ha scritto:
>>> system sparc-rtems4.11-gdb
> ______________________________**_________________
> rtems-users mailing list
> rtems-users at rtems.org
> http://www.rtems.org/mailman/**listinfo/rtems-users<http://www.rtems.org/mailman/listinfo/rtems-users>
URL: <http://lists.rtems.org/pipermail/users/attachments/20120906/50f12a8c/attachment-0001.html>
