Deadline miss in periodic tasks
Gedare Bloom
gedare at rtems.org
Fri Sep 7 16:31:26 UTC 2012
On Fri, Sep 7, 2012 at 11:22 AM, Fered <a_Fered at yahoo.com> wrote:
> Joel Sherrill wrote:
>> On 09/07/2012 02:14 AM, Fered wrote:
>> > Hi;
>> > In periodic tasks, if a task misses its deadline at middle of its
>> > execution, is the task stopped or it continues and just the
>> > rtems_rate_monotonic_period() function returns RTEMS_TIMEOUT?
>> If you are using the Deterministic Priority Scheduler (default)
>> or the Earliest Deadline First, this is the case.
>> If you are using the Constant Bandwidth Scheduler algorithm,
>> then it can detect when a thread is not going to make its
>> deadline and give you options to deal with that.
>> But in general, the task continues to execute after the period.
>> There is no magic way for RTEMS to make you go back to
>> the top of the loop without the user callbacks supported by the
>> CBS algorithm. When you get the RTEMS_TIMEOUT, you have
>> to know what that means to that task.
>> > Thanks.
>> > _______________________________________________
>> > rtems-users mailing list
>> > rtems-users at rtems.org
>> > http://www.rtems.org/mailman/listinfo/rtems-users
>> Joel Sherrill, Ph.D. Director of Research& Development
>> joel.sherrill at OARcorp.com On-Line Applications Research
>> Ask me about RTEMS: a free RTOS Huntsville AL 35805
>> Support Available (256) 722-9985
> Thank you Joel.
> If the task continues after deadline, then next periods will be shifted. Is it
> true?
I think so. IIRC the period timer is reset when the task polls its
periodic timer.
> How can I use EDF scheduler? I should assign priorities according to periods
> or there is some facilities in RTEMS?
> How can I use Constant Band Scheduler? I should implement it myself?
There are some examples in spedfsched and spcbssched under sptests,
and some documentation in the Scheduling section of the Manuals.
