_Internal_error_Occurred() in _Thread_Handler()
Matthew J Fletcher
amimjf at gmail.com
Wed Apr 3 09:11:51 UTC 2013
Sebastian,
The example from my previous post will drop into any of the samples, all
you need is a time tick to test it.
> In which context do you look at executing->Start->entry_point?
I have a breakpoint in _Internal_error_occurred() i then go up the
callstack into _Thread_Handler.
On 3 April 2013 08:15, Sebastian Huber
<sebastian.huber at embedded-brains.de>wrote:
> On 04/02/2013 05:31 PM, Matthew J Fletcher wrote:
>> Hi,
>> Ok, so i enclosed the child thread call to rtems_task_wait_after() in a
>> never
>> ending for loop expecting no error to be thrown (as the thread never
>> returns)
>> and i still end up in _Internal_error_Occured from _Thread_Handler.
> If you provide a self-contained test case, then I can test it.
>> This is all in 4.10.2. I've run the following several times now, same
>> result, i
>> dont see how the rtems_task_wake_after() is breaking out of the for(;;) to
>> return. But looking at the executing->Start->entry_point in
>> _Thread_Handler
>> test_wake_after() was the last task run.
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
> E-Mail : sebastian.huber at embedded-**brains.de<sebastian.huber at embedded-brains.de>
> ______________________________**_________________
> rtems-users mailing list
> rtems-users at rtems.org
> http://www.rtems.org/mailman/**listinfo/rtems-users<http://www.rtems.org/mailman/listinfo/rtems-users>
regards
Matthew J Fletcher
URL: <http://lists.rtems.org/pipermail/users/attachments/20130403/5a90a3c1/attachment.html>
