_Internal_error_Occurred() in _Thread_Handler()
Matthew J Fletcher
amimjf at gmail.com
Wed Apr 3 09:44:49 UTC 2013
Sebastian,
> then the system is broken. This can be a general memory corruption
(heap, stack, global > variables) or a bug in the exception processing.
Do you know where the rtems executive tests for and detects a return from a
thread so i can investigate further ?
On 3 April 2013 10:39, Sebastian Huber
<sebastian.huber at embedded-brains.de>wrote:
> On 04/03/2013 11:11 AM, Matthew J Fletcher wrote:
>> Sebastian,
>> The example from my previous post will drop into any of the samples, all
>> you
>> need is a time tick to test it.
> In another email you write:
> "A simple case as shown bellow does NOT fail, but a more complex example
> with 30+ tasks, 40+ timers etc does seem to reproducibly fail."
> I need a self contained test case that reproduces the problem to help you.
>> > In which context do you look at executing->Start->entry_point?
>> I have a breakpoint in _Internal_error_occurred() i then go up the
>> callstack
>> into _Thread_Handler.
> Ok, if you end up here with the following task
> rtems_task test_wake_after(rtems_task_**argument ignored)
> for(;;)
> rtems_task_wake_after(10);
> /* application code happening on interval here */
> then the system is broken. This can be a general memory corruption (heap,
> stack, global variables) or a bug in the exception processing.
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
> E-Mail : sebastian.huber at embedded-**brains.de<sebastian.huber at embedded-brains.de>
regards
Matthew J Fletcher
URL: <http://lists.rtems.org/pipermail/users/attachments/20130403/dc9be3cc/attachment.html>
