Mingw autoconf 2.69 package
Matthew J Fletcher
amimjf at gmail.com
Wed Apr 3 15:29:01 UTC 2013
Ralf,
Thanks, i had not installed automake, that resolves the issue with
Autom4te/ChannelDefs.pm
but i still have an error about not being able to find Autom4te/C4che.pm,
although doing a search on disk shows there is a copy in
C:\mingw\opt\rtems-4.11\share\Autom4te\
--- snip ----
Can't locate Autom4te/C4che.pm in @INC (@INC contains:
/opt/rtems-4.11/share/autoconf /usr/lib/perl5/5.8/msys /usr/lib/p
erl5/5.8 /usr/lib/perl5/site_perl/5.8/msys /usr/lib/perl5/site_perl/5.8
/usr/lib/perl5/site_perl/5.8 /usr/lib/perl5/vend
or_perl/5.8/msys /usr/lib/perl5/vendor_perl/5.8
/usr/lib/perl5/vendor_perl/5.8 .) at /mingw/bin/autom4te line 37.
BEGIN failed--compilation aborted at /mingw/bin/autom4te line 37.
aclocal-1.11: autom4te failed with exit status: 2
--- end ----
Do i have to perform any kind of re-generation step ? i've closed the mingw
shell and re-opened it, same result.
On 3 April 2013 16:07, Ralf Corsepius <ralf.corsepius at rtems.org> wrote:
> On 04/03/2013 04:33 PM, Matthew J Fletcher wrote:
>> Hi,
>> >I always build the Autotools from source in MinGW/MSYS.
> There should not be any reason to do so.
> You have to
>> make sure, that >your M4 is reasonably up to date (I use M4 1.4.7).
> 1.4.7 is quite outdated.
> As autoconf tells:
> M4 1.4.6 or later is required; 1.4.16 or newer is recommended.
> M4 1.4.14 here.
>> >A "./bootstrap" doesn't work for me. I use "./bootstrap -g".
>> Same issue about Perl include paths, i think i've managed to not
>> 'install' the pre-built autoconf correctly.
> You need to install both automake and autoconf.
> The warning "Can't locate Autom4te/ChannelDefs.pm in @INC"
> refers to a file which is provided by automake, which would indicate you
> don't have automake installed.
> Ralf
> ______________________________**_________________
> rtems-users mailing list
> rtems-users at rtems.org
> http://www.rtems.org/mailman/**listinfo/rtems-users<http://www.rtems.org/mailman/listinfo/rtems-users>
regards
Matthew J Fletcher
URL: <http://lists.rtems.org/pipermail/users/attachments/20130403/1b3b2b9d/attachment.html>
