Instructions for building and running RTEMS on the Raspberry Pi
Alan Cudmore alan.cudmore at gmail.com
Fri Apr 5 15:37:22 UTC 2013
Hi,
I wanted to post an announcement over on the Raspberrypi.org forums about
the RTEMS BSP that is in the git head.
Since it take a little bit of work to get an RTEMS development environment
up and running, I thought I would put together a short introduction to
RTEMS and a set of instructions on getting an RTEMS environment working for
the Raspberry Pi BSP.
The instructions are centered around Ubuntu 12.10 using the RTEMS Source
builder tool, but I have also put up an entry on how to setup the compiler
on Windows 7.
I have an RTEMS 4.11 development environment working on Ubuntu 12.10 with
the source builder toolchain, on CentOS 6.4 with the RTEMS toolchain RPMs,
and on Windows 7 with the RTEMS Mingw-w64 tools.
The instructions are hosted here:
http://alanstechnotes.blogspot.com/2013/03/rtems-on-raspberry-pi.html
Alan
URL: <http://lists.rtems.org/pipermail/users/attachments/20130405/bd0c9b1b/attachment.html>
