build issue with leon2 bsp code
Milo H. Fields
mfields at paladin-sys.com
Sun Apr 7 04:03:51 UTC 2013
Greetings,
I believe there may be a problem with the bsp code for leon2 bsp. When
configured with 'CONSOLE_USE_INTERRUPTS=1' the resulting make will result in
a file not found error for 'ringbuf.h' for the compile of the file
'c/src/lib/libbsp/sparc/leon2/console/console.c'.
b-leon2 Config:
../rtems-4.11/configure --target=sparc-rtems \
--enable-rtemsbsp=leon2 \
--prefix=<rtems-install> --enable-posix \
To work around the issue I revised 'console.c ' line 73 from
#include <ringbuf.h>
To
#include <rtems/ringbuf.h>
However I assume a change in 'Makefile.am' tree is preferred..
This was discovered on an older version however it was verified 4.11 with
the current 'git' pull.
URL: <http://lists.rtems.org/pipermail/users/attachments/20130407/f563d841/attachment.html>
Type: application/pkcs7-signature
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20130407/f563d841/attachment.bin>
