No GDB file
Binkowski, Cassio
cassioiks at gmail.com
Sun Apr 28 14:43:37 UTC 2013
Ok. I cloned the repo and was able to make it.
Trying to run sim-scripts/psim gives me the following: "Unable to find a
way to run powerpc/psim"
Trying to run sim-scripts/psim-gdb gives me the following: "Unable to find
a GDB for powerpc along your PATH"
I have added /rtems-testing/bin to the PATH.
Do you have any ideas?
Thanks.
On Sun, Apr 28, 2013 at 10:27 AM, Joel Sherrill
<Joel.Sherrill at oarcorp.com>wrote:
> Invoking the PowerPC simulator to run the psim bsp requires a complicated invocation with a device tree file. Trying to remember all the nuances of invoking each simulator is why rtems-testing/sim-scripts exists.
> Clone the repo. Type make and you will get psim and psim-gsb scripts which should work
> Gedare Bloom <gedare at rtems.org> wrote:
> Try powerpc-rtems4.11-run filename.exe
> Or check out rtems-testing.git and use the sim-scripts/psim
> path/to/filename.exe
> On Apr 27, 2013 10:12 PM, "Binkowski, Cassio" <cassioiks at gmail.com> wrote:
>> Ok. Installed it.
>> When I try to run my .exe (and an example one) it returns the following:
>> *rtems-4.10.99.0(PowerPC/Generic (classic FPU)/psim) PANIC cannot
>> initialize exceptions*
>> *core_find_mapping() - access to unmaped address, attach a default map
>> to handle this - addr=0xc131000 nr_bytes=0x4 processor=0x7bfe000 cia=0x16dc
>> If I type "bt" in the command line, it returns "Target is executing.".
>> Does anybody know what can be done?
>> Thanks.
>> On Sat, Apr 27, 2013 at 9:22 PM, Joel Sherrill <Joel.Sherrill at oarcorp.com
>> > wrote:
>>> You would have had to explicitly install or build gdb. PowerPC gdb is supported and uses the psim bsp.
>>> Hi all,
>>> I have built RTEMS from source for PowerPC a while ago, but I have
>>> just realized there is no powerpc-rtems4.11-gdb file, thus not allowing me
>>> to test my .exe.
>>> Is that correct? Have I built it wrongly? Is there another way to test
>>> it?
>>> Thanks.
>>> Cassio
>> rtems-users mailing list
>> rtems-users at rtems.org
>> http://www.rtems.org/mailman/listinfo/rtems-users
URL: <http://lists.rtems.org/pipermail/users/attachments/20130428/369b4082/attachment.html>
