GSOC13:hello world program
Gedare Bloom
gedare at rtems.org
Wed Apr 3 14:29:07 UTC 2013
Check your path...
$ echo $PATH
Make sure it includes the installed tools. I think they are probably
at /opt/rtems4-11/bin and you should check to see if the
sparc-rtems4.11-gdb is included there.
I haven't checked on the VM recently, so I don't know if there is
something else wrong. You should check what is in your directory with
ls and see if there is some other subdirectories in which rtems has
been placed.
-Gedare
On Tue, Apr 2, 2013 at 12:07 PM, Jaskaran Virdi <jaskaranvirdi at ymail.com> wrote:
> Hi
> I have setup the virtual machine CentOS RTEMS 4.11 on Windows 7 and have
> also updated the OS.However, on the terminal
> the command
> bash-4.1$ sparc-rtems4.11-gdb hello.exe
> it gives the error message
> bash: sparc-rtems4.11-gdb:command not found.
> Thanks for the reply.
> Jaskaran Singh
> GSOC'13 aspirant
> rtems-users mailing list
> rtems-users at rtems.org
