Building BSPs rtems 4.11 CentOS 6.4 (Final)
Milo H. Fields mfields at paladin-sys.com
Tue Apr 2 16:14:59 UTC 2013
Greetings,
I've done a cursory examination of the email archives and didn't find a
reference to my particular situation - sorry if I missed the obvious...
I've installed the 'prebuilt' 4.11 system to my CentOS 6.4 (final) using the
yum option and have cloned the basic 'git' package to my local user space as
described in your Quick Start instructions however I am not able to build
the BSP's (sis, leon2, leon3 - log is attached). As the system fails in
'bspbuild'/tools/build/configure.  The problem appears to start with the
host compiler invocation (line 103 of the log). I was able to complete the
BSP build on the CentOS VM provided so I assume the updated host tool suite
is the problem. Is this a identified issue - if so is there a work-around?
v/r
Milo
URL: <http://lists.rtems.org/pipermail/users/attachments/20130402/8e66dd08/attachment.html>
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20130402/8e66dd08/attachment.obj>
Type: application/pkcs7-signature
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20130402/8e66dd08/attachment.bin>
