Instructions for building and running RTEMS on the Raspberry Pi
Alan Cudmore
alan.cudmore at gmail.com
Fri Apr 5 22:39:02 UTC 2013
Great! I have not tried the BSP on a Model A, but it should work.
The mingw tools should work on XP, I would imagine that you want the 32
bit versions of the TDM Mingw compiler and the RTEMS tools.
I have some slightly different instructions for building on Windows with
the mingw tools, but have not written them up yet.
Let me know how it goes.
Alan
On 4/5/2013 4:31 PM, warm38 wrote:
> Alan, what a coincidence, I JUST now received 3 Model A RaspberryPi's
> via snailmail before checking my email.
> I took a quick breeze through your pages and <ooof!> now I have to go
> off to a high speed site and download a ton of stuff (I'm bandwidth
> limited).
> My Linux box died a while back so all I have is a windozeXP
> environment for development <sigh> and I need all those tools to work
> on that (which means all the downloads for the development environment).
> wade in florida
> On Fri, 5 Apr 2013 11:37:22 -0400 Alan Cudmore <alan.cudmore at gmail.com
> <mailto:alan.cudmore at gmail.com>> writes:
> Hi,
> I wanted to post an announcement over on the Raspberrypi.org
> forums about the RTEMS BSP that is in the git head.
> Since it take a little bit of work to get an RTEMS development
> environment up and running, I thought I would put together a short
> introduction to RTEMS and a set of instructions on getting an
> RTEMS environment working for the Raspberry Pi BSP.
> The instructions are centered around Ubuntu 12.10 using the RTEMS
> Source builder tool, but I have also put up an entry on how to
> setup the compiler on Windows 7.
> I have an RTEMS 4.11 development environment working on Ubuntu
> 12.10 with the source builder toolchain, on CentOS 6.4 with the
> RTEMS toolchain RPMs, and on Windows 7 with the RTEMS Mingw-w64 tools.
> The instructions are hosted here:
> http://alanstechnotes.blogspot.com/2013/03/rtems-on-raspberry-pi.html
> Alan
URL: <http://lists.rtems.org/pipermail/users/attachments/20130405/a30d58e7/attachment-0001.html>
