build stuck: rtems-4.10.2, arm-elf, nds
Wed Apr 10 15:34:49 UTC 2013
Matt,
A new project, RTEMS Source Builder (RSB) [1] can be helpful to
compile toolchains from source. It is new, so some bugs need to be
worked out. This project provides build sets with configured versions
of the required toolchain and support libraries. All the sources for
the toolchain are downloaded and compiled by the RSB tool.
The "official" documentation on toolchains can be found at [2],
although I think this document suffers bit rot.
For some distributions (mainly, Linux distros with RPM-based
packaging) there are also prebuilt toolchains available [3].
[1] http://www.rtems.org/wiki/index.php/RTEMS_Source_Builder
[2] http://rtems.org/onlinedocs/doc-current/share/rtems/html/started/index.html
[3] http://wiki.rtems.org/wiki/index.php/RTEMS_Prebuilt_Tools
-Gedare
On Wed, Apr 10, 2013 at 9:43 AM, Matt Wette <mwette at alumni.caltech.edu> wrote:
> On Apr 10, 2013, at 6:23 AM, Gedare Bloom wrote:
>> Looks like you found the error. Were you following some bad
>> instructions somewhere that we should fix?
> I could not find explicit instructions for building the toolchain.   I did find reference to gcc name prefix and arm-elf, but no the rest.
> (So I went with my experience.   In the 1990's I built the gcc toolchain 100's of times for vxworks-ppc,68k etc.)
> I will see how it goes.
> Thanks,
> Matt
> rtems-users mailing list
> rtems-users at rtems.org
