Raspberry Pi build
Cudmore, Alan P. (GSFC-5820)
alan.p.cudmore at nasa.gov
Thu Apr 11 13:42:28 UTC 2013
I don't think I have tried to build the tools on CentOS. I made sure the Raspberry Pi BSP compiled using the arm-rtemseabi4.11 RPMs for CentOS.
I have used the Rtems Source Builder tool to build a toolchain on Ubuntu 12.10, OS X, and on the Raspberry Pi itself, which is a form of Debian.
Alan
On Apr 11, 2013, at 9:30 AM, Mathew Benson <mathew.benson at gmail.com<mailto:mathew.benson at gmail.com>> wrote:
I also had to build m4 from source.
On Thu, Apr 11, 2013 at 7:22 AM, Mathew Benson <mathew.benson at gmail.com<mailto:mathew.benson at gmail.com>> wrote:
I started building this last night from Alan's instructions. Maybe I missed it in the documentation, but the build process requires glibc-static on CentOS. The build fails with a difficult to diagnose error. At least difficult to find late at night. I was getting a "compiler cannot build executables" error. The RTEMS wiki has something on that, but it pointed me in the wrong direction. I had to write a sample .c and compile it manually with the same switches to determine which switch was causing the failure. Then determine which library is required for the offending switch. Once I ran "yum install glibc-static", that step passed.
rtems-users mailing list
rtems-users at rtems.org<mailto:rtems-users at rtems.org>
http://www.rtems.org/mailman/listinfo/rtems-users
URL: <http://lists.rtems.org/pipermail/users/attachments/20130411/cbfc079a/attachment-0001.html>
