Paravirtualization project - GSOC 2013
Philipp Eppelt
philipp.eppelt at mailbox.tu-dresden.de
Mon Apr 15 12:51:09 UTC 2013
Hi,
yes, that's better. This way we just need to introduce one new
configuration parameter and don't have to touch the others.
I would prefer --enable-virt over --enable-bsp="virt", because the BSP
name should stay the same, nonetheless we are running virtually.
What's your opinion on the directory structure?
c/src/lib/libbsp/virt/<bsp_name>
c/src/lib/libbsp/virt/share
cpukit/score/cpu/virt/<cpu_name>
cpukit/score/cpu/virt/share
Regards,
Philipp
On 04/14/2013 11:54 PM, Cláudio Silva wrote:
> Hi,
> I think developing an interface really independent from the hardware
> will be difficult. You will end up with some hardware dependent code.
> Nevertheless, the inclusion of a virtualization BSP on the tree has to
> be better analyzed and discussed, due to the constraints on how the BSPs
> and CPU targets are handled.
> I would prefer to maintain the target option and add something like
> --enable-virt ou --enable-bsp="virt"; We probably want to minimize the
> virtualization interface and keep it close to the processor as possible.
> Hence, you will probably end up with something which is partially bound
> to a given CPU architecture.
> Cláudio
> On Sat, Apr 13, 2013 at 5:47 PM, Philipp Eppelt
> <philipp.eppelt at mailbox.tu-dresden.de
> <mailto:philipp.eppelt at mailbox.tu-dresden.de>> wrote:
> Hi,
> I was thinking about the CPU issue mentioned in the last years ARINC
> 653 project.
> How can a BSP be written, that has no corresponding CPU?
> To be precise:
> c/src/lib/libbsp/paraVirt/
> without cpukit/score/cpu/paraVirt/
> This should ease the usage across different CPUs. So the amount of
> platform dependent code is reduced.
> But another idea crossed my mind. Why not use a approach similar to
> the no_cpu?
> This would mean to provide a virtual CPU model with a manual
> describing how to fill in the CPU dependent code.
> Also, introduce a x86_virt (sparc_virt, sparc64_virt and so on) CPU
> model.
> To prevent clobbering the cpukit/score/cpu/ directory they all go
> into cpukit/score/cpu/virtCPU/ and an additional configuration
> parameter should specify the cpu used.
> So instead of --target=i386-rtems4.11 we use --target=virt-rtems4.11
> --enableVirtualCPU=i386. (like --enableBSP=)
> And the platform independent stuff goes into
> cpukit/score/cpu/virtCPU/__shared
> What do you think? Is this feasible?
> Regards,
> Philipp
> _________________________________________________
> rtems-users mailing list
> rtems-users at rtems.org <mailto:rtems-users at rtems.org>
> http://www.rtems.org/mailman/__listinfo/rtems-users
> <http://www.rtems.org/mailman/listinfo/rtems-users>
