Unaligned problem when porting rtems for arm
Peng Fan
van.freenix at gmail.com
Wed Apr 24 13:45:14 UTC 2013
Hi,
2013/4/24 Joel Sherrill <Joel.Sherrill at oarcorp.com>
> The arm gdb bsp is intended to help find the correct options. They could
> be wrong. When I did the bsp variants, I picked CPU variants that looked to
> hit various multilibs.
> The arm had a lot of CPU models and it is easy to make a mistake. Is this
> with the bsp for the simulator in gdb?
I am porting RTEMS to a hardware board based on S3C6410, not for the
simulator for gdb.
> --joel
> Gedare Bloom <gedare at rtems.org> wrote:
> Given the newness of this port, I would guess the options are wrong.
> On Wed, Apr 24, 2013 at 9:19 AM, Sebastian Huber
> <sebastian.huber at embedded-brains.de> wrote:
> > Hello,
> > in case GCC uses a half-word load or store where it shouldn't, then you
> have
> > 1. wrong compiler options, or
> > 2. a compiler bug.
> > Sebastian Huber, embedded brains GmbH
> > Address : Dornierstr. 4, D-82178 Puchheim, Germany
> > Phone : +49 89 189 47 41-16
> > Fax : +49 89 189 47 41-09
> > E-Mail : sebastian.huber at embedded-brains.de
> > PGP : Public key available on request.
> > Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
> > rtems-users mailing list
> > rtems-users at rtems.org
> > http://www.rtems.org/mailman/listinfo/rtems-users
URL: <http://lists.rtems.org/pipermail/users/attachments/20130424/b10bf9d9/attachment-0001.html>
