No GDB file
Joel Sherrill
joel.sherrill at OARcorp.com
Sun Apr 28 16:43:34 UTC 2013
On 4/28/2013 9:43 AM, Binkowski, Cassio wrote:
> Ok. I cloned the repo and was able to make it./
> Trying to run sim-scripts/psim gives me the following: "Unable to find
> a way to run powerpc/psim"
> Trying to run sim-scripts/psim-gdb gives me the following: "Unable to
> find a GDB for powerpc along your PATH"
Is powerpc-rtems4.11-gdb in your PATH?
This is just a script that wraps gdb. It writes a device file and
invokes powerpc-rtemsXXX-gdb
with the appropriate arguments.
> I have added /rtems-testing/bin to the PATH.
That is how you found psim and psim-gdb. Where is powerpc-rtems4.11-gdb
> Do you have any ideas?
> Thanks.
> On Sun, Apr 28, 2013 at 10:27 AM, Joel Sherrill
> <Joel.Sherrill at oarcorp.com <mailto:Joel.Sherrill at oarcorp.com>> wrote:
> Invoking the PowerPC simulator to run the psim bsp requires a complicated invocation with a device tree file. Trying to remember all the nuances of invoking each simulator is why rtems-testing/sim-scripts exists.
> Clone the repo. Type make and you will get psim and psim-gsb scripts which should work
> Gedare Bloom <gedare at rtems.org <mailto:gedare at rtems.org>> wrote:
> Try powerpc-rtems4.11-run filename.exe
> Or check out rtems-testing.git and use the sim-scripts/psim
> path/to/filename.exe
> On Apr 27, 2013 10:12 PM, "Binkowski, Cassio" <cassioiks at gmail.com
> <mailto:cassioiks at gmail.com>> wrote:
> Ok. Installed it.
> When I try to run my .exe (and an example one) it returns the
> following:
> /rtems-4.10.99.0(PowerPC/Generic (classic FPU)/psim) PANIC
> cannot initialize exceptions/
> /core_find_mapping() - access to unmaped address, attach a
> default map to handle this - addr=0xc131000 nr_bytes=0x4
> processor=0x7bfe000 cia=0x16dc/
> If I type "bt" in the command line, it returns "Target is
> executing.".
> Does anybody know what can be done?
> Thanks.
> On Sat, Apr 27, 2013 at 9:22 PM, Joel Sherrill
> wrote:
> You would have had to explicitly install or build gdb. PowerPC gdb is supported and uses the psim bsp.
> "Binkowski, Cassio" <cassioiks at gmail.com <mailto:cassioiks at gmail.com>> wrote:
> Hi all,
> I have built RTEMS from source for PowerPC a while ago,
> but I have just realized there is no powerpc-rtems4.11-gdb
> file, thus not allowing me to test my .exe.
> Is that correct? Have I built it wrongly? Is there another
> way to test it?
> Thanks.
> Cassio
> rtems-users mailing list
> rtems-users at rtems.org <mailto:rtems-users at rtems.org>
URL: <http://lists.rtems.org/pipermail/users/attachments/20130428/805976e9/attachment-0001.html>
