posix_memalign
Daron Chabot
daron.chabot at gmail.com
Tue Apr 30 17:12:59 UTC 2013
On Tue, Apr 30, 2013 at 3:41 AM, Sebastian Huber <
> On 04/29/2013 10:57 PM, Daron Chabot wrote:
>> Hi,
>> I'm working with RTEMS 4.9.3 and the mvme3100 BSP
>> In trying to emulate the vxworks function, memalign( ), and it looks like:
>> 1) there is no equivalent in RTEMS, but it's prototyped in newlib
>> 2) posix_memalign( ) is defined in cpukit/libcsupport/src, but does not
>> appear
>> in any headers and cannot be linked against. It's definitely in
>> librtemscpu.a:
>> dchabot at dev32new--> nm /usr/powerpc-rtems4.9/**mvme3100/lib/librtemscpu.a
>> libcsupport_a-posix_memalign.**o:
>> 00000000 T posix_memalign
>> U rtems_malloc_statistics
>> U rtems_memalign
> What is the linker problem with this function?
Sorry, my mistake. Once I added a prototype for posix_memalign, all is well
with the linker.
Note, the prototype is missing from the version of newlib's "stdlib.h" that
we're using with RTEMS 4.9.3.
I see Ralf had posted a patch upstream back in 2009 (
http://sourceware.org/ml/newlib/2009/msg00924.html).
> 3) rtems_memalign( ) appears to be the only functional variant
>> Is there a more elegant solution here than creating my own memalign( )
>> wrapper
>> around rtems_memalign( ) ? It seems like an error to not have a
>> posix_memalign(
>> ) available...
> Since memalign() has a prototype in Newlib's <malloc.h> you can simply add
> an implementation to cpukit/libcsupport and a test case to
> testsuites/libtests/memalign01 if you want.
I'd prefer to use posix_memalign, as it seems the use of memalign is being
deprecated/made obsolete (from the man-page).
Thanks, Sebastian.
-- dc
URL: <http://lists.rtems.org/pipermail/users/attachments/20130430/a17a5398/attachment-0001.html>
