posix_memalign
Tue Apr 30 07:41:00 UTC 2013
On 04/29/2013 10:57 PM, Daron Chabot wrote:
> Hi,
> I'm working with RTEMS 4.9.3 and the mvme3100 BSP
> In trying to emulate the vxworks function, memalign( ), and it looks like:
> 1) there is no equivalent in RTEMS, but it's prototyped in newlib
> 2) posix_memalign( ) is defined in cpukit/libcsupport/src, but does not appear
> in any headers and cannot be linked against. It's definitely in librtemscpu.a:
> dchabot at dev32new--> nm /usr/powerpc-rtems4.9/mvme3100/lib/librtemscpu.a
> libcsupport_a-posix_memalign.o:
> 00000000 T posix_memalign
>           U rtems_malloc_statistics
>           U rtems_memalign
What is the linker problem with this function?
> 3) rtems_memalign( ) appears to be the only functional variant
> Is there a more elegant solution here than creating my own memalign( ) wrapper
> around rtems_memalign( ) ? It seems like an error to not have a posix_memalign(
> ) available...
Since memalign() has a prototype in Newlib's <malloc.h> you can simply add an
implementation to cpukit/libcsupport and a test case to
testsuites/libtests/memalign01 if you want.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
