rtems_error(RTEMS_ERROR_PANIC, (...)) and rtems_error(RTEMS_ERROR_ABORT, (...)) both reset?
Mon Aug 5 07:49:44 UTC 2013
Hello,
On 2013-08-05 08:11, Nick Withers wrote:
> Hi there!
> It seems that rtems_error(RTEMS_ERROR_PANIC, (...)) and
> rtems_error(RTEMS_ERROR_ABORT, (...)) both cause resets on the MVME3100
> board I'm using with RTEMS Git HEAD (updated today).
> I believe this differs from 4.10 but have run into some troubles on my
> side trying to verify this.
> Is the behaviour I'm seeing intentional? I was under the impression
> (e.g., from
> http://www.rtems.org/onlinedocs/doxygen/cpukit/html/error_8h.html#details ) that the RTEMS_ERROR_PANIC case should leave the system up but halted...?
yes, the system termination handling changed from RTEMS 4.10.  Now every
terminating execution path (unexpected exception, exit(), etc.) should end up
in _Internal_error_Occurred() which invokes the fatal error extensions.
http://www.rtems.org/wiki/index.php/4.11_Release_Notes
http://www.rtems.org/onlinedocs/doxygen/cpukit/html/group__ScoreIntErr.html
The application can provide an initial extension to do application specific
termination handling.
The default provided by the BSP is to call bsp_reset().
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
