MinGW
Thu Aug 8 01:04:36 UTC 2013
Sebastian Huber wrote:
> you can use the RTEMS Source Builder (RSB) for this:
> http://wiki.rtems.org/wiki/index.php/RTEMS_Source_Builder
> I normally build the MinGW tools on Linux.
I just built a new ARM compiler for MinGW using the RSB on FreeBSD using ...
../source-builder/sb-set-builder --host=mingw32 --trace --log=log_arm
--prefix=/opt/rtems/4.11 --no-install --bset-tar-file 4.11/rtems-arm
You can find the tar file with the binaries at ...
http://www.rtems.org/ftp/pub/rtems/people/chrisj/source-builder/4.11/mingw32/
I will add more architectures as they become available. These tools
contain all required patches and should work on RTEMS 4.11 master.
Using autoconf and automake in MSYS may require 'mount c:/opt/rtems/4.11
/opt/rtems/4.11" where "c:/opt/rtems/4.11" is the path to where you
unpacked the tar file. The tool such as arm-rtems4.11-as,
arm-rtems4.11-gcc should be relocatable.
