MinGW
Sebastian Huber
Wed Aug 7 11:07:58 UTC 2013
Hello Simon,
you can use the RTEMS Source Builder (RSB) for this:
http://wiki.rtems.org/wiki/index.php/RTEMS_Source_Builder
I normally build the MinGW tools on Linux.
The MinGW tools from here should work:
ftp://ftp.rtems.org/pub/rtems/mingw64/4.11/i686/
These tools however use an outdated Newlib which doesn't contain some bug fixes
included in the RSB version.
On 2013-08-07 09:36, Simon Williams wrote:
> I wonder if anyone can help with a problem I've got building RTEMS on Windows.
> I have installed MinGW and the RTEMS MinGW toolchain for Arm from the RTEMS
> ftp site. I then cloned the git repository ran bootstrap and configure without
> any problem. When I come to build however, I get an error telling me that the
> compiler is broken. Doing gcc -v --version confirms the issue. It is caused by
> cc1 encountering an architecture mismatch. I tried to rebuild the toolchain
> from the sources on the ftp site, but configure appears to be mangling the
> arm-rtems4.11 target to arm-unknown-rtems4.11, which appears from research I've
> done to be an old issue!
> My thought is that building a native toolchain from the RTEMS tools source
> first and then using the result to build the Arm toolchain may resolve the
> issue, but, given the time it will take, I wanted to get some sort of
> reassurance I wasn't wasting my time.
> I am restricted to using Windows for my development environment as .Net
> development is what pays the bills!
> rtems-users mailing list
> rtems-users at rtems.org
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
