Compiling Rtems by another compiler
Ehsan Salmanpour
salmanpour.ehsan at yahoo.com
Sat Aug 10 18:59:34 UTC 2013
I don't need to compile with this compiler. As I said before I want to compile RTEMS for arm7 that can be simulated in SimpleScalar. when I use the original compiler of RTEMS (as mentioned in Docs) the SimpleScaler does NOT recognize the binary of the output.
________________________________
From: Sebastian Huber <sebastian.huber at embedded-brains.de>
To: rtems-users at rtems.org
Sent: Friday, August 9, 2013 10:27 AM
Subject: Re: Compiling Rtems by another compiler
On 2013-08-08 21:59, Ehsan Salmanpour wrote:
> Hi Everyone!
> I want to know is it possible to compile RTEMS with another compile like:
> *SimpleScalar/ARM Cross Compiler*
> (https://sites.google.com/site/pkuwangh/solutions/arm_cross)
> How?
> My goal is compile Rtems for arm7 that can be simulated in SimpleScalar.
Why do you need this compiler? The RTEMS GCC emits standard EABI version 5 code.
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
rtems-users mailing list
http://www.rtems.org/mailman/listinfo/rtems-users
URL: <http://lists.rtems.org/pipermail/users/attachments/20130810/e89a12b0/attachment-0001.html>
