booting rtems on MVME2432
John Dobbins john.dobbins at cornell.edu
Thu Feb 7 20:59:01 UTC 2013
All,
I am trying to boot rtems on an MVME2432 board.
I am experiencing a problem similar to one which has been reported before
(see http://www.rtems.com/ml/rtems-users/2012/march/msg00237.html )
but for which I haven't seen a solution posted.
The problem is this, the rtems kernel determines my board to be an
unknown motorola board.
RTEMS 4.x/PPC load:
Uncompressing the kernel...
done
Now booting...
Unknown motorola board Please update
libbsp/powerpc/shared/motorola/motorola.c
cpu_type = E0
base_mod = F9
Welcome to rtems-4.10.2(PowerPC/Generic (classic FPU)/mcp750) on Unknown
motorola board
The file
rtems-4.10.2/src/rtems-4.10.2/c/src/lib/libbsp/powerpc/shared/motorola/motorola.c
contains the lines
   {0x0E0, 0xF9, PPC_604,     "MVME 2400",
mvme24xx_intmap,prep_pci_swizzle},
   {0x3E0, 0x00, PPC_750,     "MVME 2400 (PPC 750)",
but for my board the reported values are
cput_type  = E0
base_mod   = F9
proc_type  = PPC_750
so I don't match either of the lines for MVME2400 family.
In fact, as far as I know, the MVME2400 was only sold with the PPC_750
cpu so I am a little puzzled by the first line.
I can certainly add a line to motorola.c for my combination of values
but as I am new to this I thought I should ask if I am missing something?
Also does anyone know if my board would use the same interrupt setup and
pci_swizzle as the existing entries?
Is anyone actively using rtems on MVME2432? Did you encounter this
problem? How do you deal with it?
Regards and thanks,
John Dobbins
Cornell University
Lab for Elementary Particle Physics
