Error while building gcc for toolset for RTEMS
Gedare Bloom
gedare at rtems.org
Sat Feb 9 02:54:42 UTC 2013
What do you get to from:
echo $PATH
which sparc-rtems4.11-gcc
On Feb 8, 2013 9:41 PM, "manish jain" <manish8886 at gmail.com> wrote:
> No that didn't also work
> *checking for style of include used by make... GNU
> checking for sparc-rtems4.11-gcc... no
> configure: error: no acceptable cc found in $PATH
> make[2]: *** [sis] Error 1
> make[2]: Leaving directory `/home/manish/tools/b-rtems/sparc-rtems4.11/c'
> make[1]: *** [all-recursive] Error 1
> make[1]: Leaving directory `/home/manish/tools/b-rtems/sparc-rtems4.11/c'
> I checked the path /opt/rtem-4.11 has sparc-rtems4.11-gcc.
> Is there might be problem in configuring the rtems project. I first did
> ./bootstrap from rtems source directory and then configure the rtems and
> tried to build it.
> Thanks
> Manish
> On Fri, Feb 8, 2013 at 10:16 AM, Gedare Bloom <gedare at rtems.org> wrote:
>> 4.11 currently refers to the development head, or master. There is no
>> 4.11 branch at the moment. Try the master branch.
>> The tools are specific to rtems version, so 4.11 tools will not build
>> rtems 4.10.x
>> -Gedare
>> On Feb 8, 2013 4:57 AM, "manish jain" <manish8886 at gmail.com> wrote:
>>> Hi All,
>>> Thanks for all your suggestions. The problem was, library cache was not
>>> updated. Now I have successfully built my tool chains for rtems-4.11.
>>> But now I am facing problem in building the RTEMS itself.
>>> I have built my tool set for rtems-4.11 but I am not able to find
>>> RTEMS-4.11 source code in git repository and CVS. All I see is that most
>>> current version is rtems.4.10.2. So I downloaded the code for rtems-4.10.2
>>> and tried to build it.
>>> I am configuring the rtems with following command:
>>> * ../rtems-4.10.2/configure --target=sparc-rtems4.11
>>> --enable-rtemsbsp=sis --disable-posix --disable-networking --disable-cxx
>>> --prefix=/opt/rtems-4.11
>>> And the error I got when I do make all is following:
>>> *configure: error: no acceptable cc found in $PATH
>>> Actually after getting the error I saw "*
>>> {build-dir/sparc-rtems4.11/c/sis/config.log}*" and problem was that in
>>> PATH: it is not including "/opt/rtems-4.11/bin" but in *
>>> "{build-dir/sparc-rtems4.11/c/config.log}*" the PATH variable is
>>> proper.
>>> And my PATH variable is set to : *
>>> /opt/rtems-4.11/bin:/usr/lib/lightdm/lightdm:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games
>>> I have looked the previous mails regarding this problem and most common
>>> cause of this error was PATH variable but I think my PATH variable is
>>> proper. I am not able to figure out why it is happening?
>>> Thanks
>>> Manish
>>> On Thu, Feb 7, 2013 at 10:19 AM, Steven Grunza <sgrunza at ctdi.com> wrote:
>>>> > -----Original Message-----
>>>> > From: rtems-users-bounces at rtems.org [mailto:rtems-users-
>>>> > bounces at rtems.org] On Behalf Of Gedare Bloom
>>>> > Sent: Thursday, February 07, 2013 9:52 AM
>>>> > To: manish jain
>>>> > Cc: RTEMS
>>>> > Subject: Re: Error while building gcc for toolset for RTEMS
>>>> > Aside from the (relatively useful) advice that you may want to try
>>>> > the prepackaged solutions, if you continue with building your own
>>>> > tools you may want to check that mpc/gmp/mpfr are being found. If
>>>> > you built/installed them separately from GCC then you need to add
>>>> > the install point to your library path, e.g. export
>>>> > LD_LIBRARY_PATH=${PREFIX}/lib:${LD_LIBRARY_PATH} for PREFIX equal
>>>> > to where you installed those libraries. If you are using a single-
>>>> > tree build where you link the source for those libraries, then gcc
>>>> > should find them itself. The error you sent is indicative of a
>>>> > missing library.
>>>> If you continue on the path of building your own tools, the command
>>>> "ldconfig -p" is your friend. This command will show you all the
>>>> libraries known and cached. If you installed a library from source and
>>>> don't see it listed, you may need to run "ldconfig" as root to update
>>>> the cache. I've mostly seen this out-of-date ld.so cache problem on
>>>> Fedora/CentOS systems but it can't hurt to check.
URL: <http://lists.rtems.org/pipermail/users/attachments/20130208/a3475cce/attachment.html>
