Error while building gcc for toolset for RTEMS
manish jain
manish8886 at gmail.com
Sat Feb 9 03:04:50 UTC 2013
Hi,
My $PATH is
/opt/rtems-4.11/bin:/usr/lib/lightdm/lightdm:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games
And I do have various binaries in /opt/rtems-4.11/bin like:
sparc-rtems4.11-gcc
sparc-rtems4.11-gcc-4.7.2
sparc-rtems4.11-gcc-ar
sparc-rtems4.11-gcc-nm
sparc-rtems4.11-gcc-ranlib
On Fri, Feb 8, 2013 at 9:54 PM, Gedare Bloom <gedare at rtems.org> wrote:
> What do you get to from:
> echo $PATH
> which sparc-rtems4.11-gcc
> On Feb 8, 2013 9:41 PM, "manish jain" <manish8886 at gmail.com> wrote:
>> No that didn't also work
>> *checking for style of include used by make... GNU
>> checking for sparc-rtems4.11-gcc... no
>> configure: error: no acceptable cc found in $PATH
>> make[2]: *** [sis] Error 1
>> make[2]: Leaving directory `/home/manish/tools/b-rtems/sparc-rtems4.11/c'
>> make[1]: *** [all-recursive] Error 1
>> make[1]: Leaving directory `/home/manish/tools/b-rtems/sparc-rtems4.11/c'
>> I checked the path /opt/rtem-4.11 has sparc-rtems4.11-gcc.
>> Is there might be problem in configuring the rtems project. I first did
>> ./bootstrap from rtems source directory and then configure the rtems and
>> tried to build it.
>> Thanks
>> Manish
>> On Fri, Feb 8, 2013 at 10:16 AM, Gedare Bloom <gedare at rtems.org> wrote:
>>> 4.11 currently refers to the development head, or master. There is no
>>> 4.11 branch at the moment. Try the master branch.
>>> The tools are specific to rtems version, so 4.11 tools will not build
>>> rtems 4.10.x
>>> -Gedare
>>> On Feb 8, 2013 4:57 AM, "manish jain" <manish8886 at gmail.com> wrote:
>>>> Hi All,
>>>> Thanks for all your suggestions. The problem was, library cache was not
>>>> updated. Now I have successfully built my tool chains for rtems-4.11.
>>>> But now I am facing problem in building the RTEMS itself.
>>>> I have built my tool set for rtems-4.11 but I am not able to find
>>>> RTEMS-4.11 source code in git repository and CVS. All I see is that most
>>>> current version is rtems.4.10.2. So I downloaded the code for rtems-4.10.2
>>>> and tried to build it.
>>>> I am configuring the rtems with following command:
>>>> * ../rtems-4.10.2/configure --target=sparc-rtems4.11
>>>> --enable-rtemsbsp=sis --disable-posix --disable-networking --disable-cxx
>>>> --prefix=/opt/rtems-4.11
>>>> And the error I got when I do make all is following:
>>>> *configure: error: no acceptable cc found in $PATH
>>>> Actually after getting the error I saw "*
>>>> {build-dir/sparc-rtems4.11/c/sis/config.log}*" and problem was that in
>>>> PATH: it is not including "/opt/rtems-4.11/bin" but in *
>>>> "{build-dir/sparc-rtems4.11/c/config.log}*" the PATH variable is
>>>> proper.
>>>> And my PATH variable is set to : *
>>>> I have looked the previous mails regarding this problem and most common
>>>> cause of this error was PATH variable but I think my PATH variable is
>>>> proper. I am not able to figure out why it is happening?
>>>> Thanks
>>>> Manish
>>>> On Thu, Feb 7, 2013 at 10:19 AM, Steven Grunza <sgrunza at ctdi.com>wrote:
>>>>> > -----Original Message-----
>>>>> > From: rtems-users-bounces at rtems.org [mailto:rtems-users-
>>>>> > bounces at rtems.org] On Behalf Of Gedare Bloom
>>>>> > Sent: Thursday, February 07, 2013 9:52 AM
>>>>> > To: manish jain
>>>>> > Cc: RTEMS
>>>>> > Subject: Re: Error while building gcc for toolset for RTEMS
>>>>> > Aside from the (relatively useful) advice that you may want to try
>>>>> > the prepackaged solutions, if you continue with building your own
>>>>> > tools you may want to check that mpc/gmp/mpfr are being found. If
>>>>> > you built/installed them separately from GCC then you need to add
>>>>> > the install point to your library path, e.g. export
>>>>> > LD_LIBRARY_PATH=${PREFIX}/lib:${LD_LIBRARY_PATH} for PREFIX equal
>>>>> > to where you installed those libraries. If you are using a single-
>>>>> > tree build where you link the source for those libraries, then gcc
>>>>> > should find them itself. The error you sent is indicative of a
>>>>> > missing library.
>>>>> If you continue on the path of building your own tools, the command
>>>>> "ldconfig -p" is your friend. This command will show you all the
>>>>> libraries known and cached. If you installed a library from source and
>>>>> don't see it listed, you may need to run "ldconfig" as root to update
>>>>> the cache. I've mostly seen this out-of-date ld.so cache problem on
>>>>> Fedora/CentOS systems but it can't hurt to check.
URL: <http://lists.rtems.org/pipermail/users/attachments/20130208/1d6c8416/attachment.html>
