Problems in boot_card() with configuration
Joel Sherrill
Joel.Sherrill at OARcorp.com
Fri Feb 15 14:10:36 UTC 2013
Could you post or privately email the broken code? I am curious if we can do anything to help avoid this or at least make it easier to debug or know what tolook for in the future.
Thanks
Matthew J Fletcher <amimjf at gmail.com> wrote:
Thanks all, but my problem was much simpler, not including confdefs.h I copied one of the included samples and am getting much further.
On 14 Feb 2013 20:14, "Joel Sherrill" <joel.sherrill at oarcorp.com<mailto:joel.sherrill at oarcorp.com>> wrote:
On 2/14/2013 2:00 PM, Matthew J Fletcher wrote:
On 14/02/13 19:38, Gedare Bloom wrote:
On Thu, Feb 14, 2013 at 2:16 PM, Joel Sherrill
On 2/14/2013 1:09 PM, Matthew J Fletcher wrote:
Hi,
I am using RTEMS 4.10.2, and a custom BSP based on the ARM rtl22xx.
I am running through the asm startup ok and calling into boot_card(),
stepping through its all working fine, work_area_start, work_area_size,
heap_start and heap_size are setup as i expect from my linkscript.
But the test of "work_area_size <= Configuration.work_space_size" fails
because Configuration.work_space_size looks like 0xfffffff, the only
place that assigns to Configuration.work_space_size is a few lines
further down.
Does this code presume that the BSP has set the Configuration structure
to zero, or the whole memory ? even so the aforementioned test seems odd
as its just testing memory has been initialised.
We do assume the .bss section is initialized to 0, although I'm not
sure if that is still a necessary assumption. But I don't think that
is the problem here, because if the value of
Configuration.work_space_size was 0 then this test would still fail.
The work_space_size calculation is done in the
cpukit/sapi/include/confdefs.h file, but that can be a bit messy to
try to figure out.
Or am i missing some RTEMS initialisation call that needs to be done
before boot_card() ?
No but there may be some basic C language assumptions not
being met. Configuration is in the .data section and that value
does not look like it was initialized to.
Is your download correct?
You can disassemble your binary image and inspect the value of the
Configuration.work_space_size field in the data section.
Sorry i dont seem to have the objdump skills, i did a -D (disassemble
all sections), although it produced massive output i dont see a
structure called 'Configuration', i get a block like
814085f4 <Configuration>:
814085f4: 00000000 andeq r0, r0, r0
814085f8: 00010830 andeq r0, r1, r0, lsr r8
This isn't code but this is enough to see that what is in memory and used
by the code is NOT what was in the object. The workspace_address field
is 0. The second field is the size and is 0x00010830. You saw 0xFFFFFFFFF.
Either the download didn't go where you thought, memory access isn't
setup write, etc.
Download and look at those two addresses BEFORE you run at all.
If you don't see those values, it is nothing to do with RTEMS. :)
.bss is uninitialized global and static date. It gets zeroed.
.data is your global and static data that is initialized.
814085fc: 00000000 andeq r0, r0, r0
81408600: 00002710 andeq r2, r0, r0, lsl r7
81408604: 00000032 andeq r0, r0, r2, lsr r0
81408608: 8118d3a0 tsthi r8, r0, lsr #7
8140860c: 00001000 andeq r1, r0, r0
81408610: 00001000 andeq r1, r0, r0
81408620: 00000002 andeq r0, r0, r2
81408624: 00000002 andeq r0, r0, r2
81408628: 8140868c smlalbbhi r8, r0, ip, r6
8140862c: 00000001 andeq r0, r0, r1
81408630: 8140866c cmphi r0, ip, ror #12
is it possible to pretty print that in some way ?
- Matthew
rtems-users mailing list
rtems-users at rtems.org<mailto:rtems-users at rtems.org>
http://www.rtems.org/mailman/listinfo/rtems-users
URL: <http://lists.rtems.org/pipermail/users/attachments/20130215/35bcc730/attachment-0001.html>
