Problems in boot_card() with configuration
Matthew J Fletcher
amimjf at gmail.com
Fri Feb 15 14:20:14 UTC 2013
Joel,
I simply had not put
#define CONFIGURE_INIT
#include <rtems/confdefs.h>
Anywhere in the code, bit of a schoolboy error so the Configuration
structure was not setup. I was creating my own bsp and just forgot that I
needed bits from on of the samples as well.
On 15 Feb 2013 14:10, "Joel Sherrill" <Joel.Sherrill at oarcorp.com> wrote:
> Could you post or privately email the broken code? I am curious if we can do anything to help avoid this or at least make it easier to debug or know what tolook for in the future.
> Thanks
> Matthew J Fletcher <amimjf at gmail.com> wrote:
> Thanks all, but my problem was much simpler, not including confdefs.h I
> copied one of the included samples and am getting much further.
> On 14 Feb 2013 20:14, "Joel Sherrill" <joel.sherrill at oarcorp.com> wrote:
>> On 2/14/2013 2:00 PM, Matthew J Fletcher wrote:
>>> On 14/02/13 19:38, Gedare Bloom wrote:
>>>> On Thu, Feb 14, 2013 at 2:16 PM, Joel Sherrill
>>>>> On 2/14/2013 1:09 PM, Matthew J Fletcher wrote:
>>>>>> Hi,
>>>>>> I am using RTEMS 4.10.2, and a custom BSP based on the ARM rtl22xx.
>>>>>> I am running through the asm startup ok and calling into boot_card(),
>>>>>> stepping through its all working fine, work_area_start,
>>>>>> work_area_size,
>>>>>> heap_start and heap_size are setup as i expect from my linkscript.
>>>>>> But the test of "work_area_size <= Configuration.work_space_size"
>>>>>> fails
>>>>>> because Configuration.work_space_size looks like 0xfffffff, the only
>>>>>> place that assigns to Configuration.work_space_size is a few lines
>>>>>> further down.
>>>>>> Does this code presume that the BSP has set the Configuration
>>>>>> structure
>>>>>> to zero, or the whole memory ? even so the aforementioned test seems
>>>>>> odd
>>>>>> as its just testing memory has been initialised.
>>>>>> We do assume the .bss section is initialized to 0, although I'm not
>>>> sure if that is still a necessary assumption. But I don't think that
>>>> is the problem here, because if the value of
>>>> Configuration.work_space_size was 0 then this test would still fail.
>>>> The work_space_size calculation is done in the
>>>> cpukit/sapi/include/confdefs.h file, but that can be a bit messy to
>>>> try to figure out.
>>>> Or am i missing some RTEMS initialisation call that needs to be done
>>>>>> before boot_card() ?
>>>>> No but there may be some basic C language assumptions not
>>>>> being met. Configuration is in the .data section and that value
>>>>> does not look like it was initialized to.
>>>>> Is your download correct?
>>>>> You can disassemble your binary image and inspect the value of the
>>>> Configuration.work_space_size field in the data section.
>>> Sorry i dont seem to have the objdump skills, i did a -D (disassemble
>>> all sections), although it produced massive output i dont see a
>>> structure called 'Configuration', i get a block like
>>> 814085f4 <Configuration>:
>>> 814085f4: 00000000 andeq r0, r0, r0
>>> 814085f8: 00010830 andeq r0, r1, r0, lsr r8
>> This isn't code but this is enough to see that what is in memory and used
>> by the code is NOT what was in the object. The workspace_address field
>> is 0. The second field is the size and is 0x00010830. You saw 0xFFFFFFFFF.
>> Either the download didn't go where you thought, memory access isn't
>> setup write, etc.
>> Download and look at those two addresses BEFORE you run at all.
>> If you don't see those values, it is nothing to do with RTEMS. :)
>> .bss is uninitialized global and static date. It gets zeroed.
>> .data is your global and static data that is initialized.
>>> 814085fc: 00000000 andeq r0, r0, r0
>>> 81408600: 00002710 andeq r2, r0, r0, lsl r7
>>> 81408604: 00000032 andeq r0, r0, r2, lsr r0
>>> 81408608: 8118d3a0 tsthi r8, r0, lsr #7
>>> 8140860c: 00001000 andeq r1, r0, r0
>>> 81408610: 00001000 andeq r1, r0, r0
>>> 81408620: 00000002 andeq r0, r0, r2
>>> 81408624: 00000002 andeq r0, r0, r2
>>> 81408628: 8140868c smlalbbhi r8, r0, ip, r6
>>> 8140862c: 00000001 andeq r0, r0, r1
>>> 81408630: 8140866c cmphi r0, ip, ror #12
>>> is it possible to pretty print that in some way ?
>>> - Matthew
>>>>>> ______________________________**_________________
>>>>>> rtems-users mailing list
>>>>>> rtems-users at rtems.org
>>>>>> http://www.rtems.org/mailman/**listinfo/rtems-users<http://www.rtems.org/mailman/listinfo/rtems-users>
>>>>> Joel Sherrill, Ph.D. Director of Research & Development
>>>>> joel.sherrill at OARcorp.com On-Line Applications Research
>>>>> Ask me about RTEMS: a free RTOS Huntsville AL 35805
>>>>> Support Available (256) 722-9985
URL: <http://lists.rtems.org/pipermail/users/attachments/20130215/b4f81e8f/attachment.html>
