confused about the rtems tool chain for windows.
Tom Smith
venture.g at gmail.com
Mon Feb 18 12:01:29 UTC 2013
hi, all
I am now confused about the rtems tool chain for windows.
I read the wiki *MinGW Tools for Windows*
"http://wiki.rtems.org/wiki/index.php/MinGW_Tools_for_Windows"
and realised that the rtems tool chain for windows does not depend MinGW
and MSYS.
So I downloaded the tool chain of arm for MinGW from the following address
http://www.rtems.org/ftp/pub/rtems/mingw32/4.11/
Then I extracted the bz2 files using 7z and set PATH in CLI under windows
following the instructions found in the above wiki page.
Finally, when I tried to compile a helloworld example c file, the tool
chian failed with the following complaint
"*arm-rtemseabi4.11-gcc.exe: error: CreateProcess: No such file or directory
*". By adding the `-v' option, I found the reason is that `as'
program(\opt\rtems-4.11\arm-rtemseabi4.11\bin) is an empty file.
Note that I did not install MinGW and MSYS , and no rtems bsp had been
installed on that computer.
I did the above steps again under mingw32, and got the same result.
So is the tool chain broken ? Any sugguestion will be appreciated. thanks
in advance.
tom
rtems-users mailing list
> rtems-users at rtems.org
> End of rtems-users Digest, Vol 77, Issue 24
URL: <http://lists.rtems.org/pipermail/users/attachments/20130218/9913bc2e/attachment.html>
