confused about the rtems tool chain for windows.
Matthew J Fletcher amimjf at gmail.com
Mon Feb 18 12:08:41 UTC 2013
Tom,
I had this problem just a few hours ago. The zero byte files are WinZip or
7zip not extracting from the tar archive correctly.
I extracted the outer archive first then the tar and it was ok with 7zip.
Its not a tool chain issue.
 On 18 Feb 2013 12:02, "Tom Smith" <venture.g at gmail.com> wrote:
> hi, all
> I am now confused about the rtems tool chain for windows.
> I read the wiki  *MinGW Tools for Windows*
> "http://wiki.rtems.org/wiki/index.php/MinGW_Tools_for_Windows"
> and realised that the rtems tool chain for windows does not depend MinGW
> and MSYS.
> So  I downloaded the tool chain of arm for MinGW from the following address
> http://www.rtems.org/ftp/pub/rtems/mingw32/4.11/
> Then I extracted the bz2 files using 7z and set PATH in CLI under windows
> following the instructions found in the above wiki page.
> Finally, when I tried to compile a helloworld example c file, the tool
> chian failed with the following complaint
> "*arm-rtemseabi4.11-gcc.exe: error: CreateProcess: No such file or
> directory*". By adding the `-v' option, I found the reason is that `as'
> program(\opt\rtems-4.11\arm-rtemseabi4.11\bin) is an empty file.
> Note that I did not install MinGW and MSYS ,  and no rtems bsp had been
> installed on that computer.
> I did the above steps again under mingw32, and got the same result.
> So is the tool chain broken ?  Any sugguestion will be appreciated.
>  thanks in advance.
> tom
> rtems-users mailing list
>> rtems-users at rtems.org
>> http://www.rtems.org/mailman/listinfo/rtems-users
>> End of rtems-users Digest, Vol 77, Issue 24
URL: <http://lists.rtems.org/pipermail/users/attachments/20130218/fb767ec4/attachment-0001.html>
