ARM (Thumb Mode) _CPU_Context_switch_arm
Joel Sherrill
joel.sherrill at OARcorp.com
Mon Feb 25 17:40:41 UTC 2013
On 2/25/2013 11:25 AM, Matthew J Fletcher wrote:
> Sebastain,
> I changed the code so now with the cpsr set as expected before main()
> the context switch occurs fine and we end up in Init().
Is this a generic issue that needs addressing in the RTEMS
git repo? Or something you broke accidentally when making
other changes?
> Thanks for all your help.
A little early for a beer here but it is definitely after 5 for
Sebastian. Good job Sebastian!
--joel
> On 25 February 2013 17:10, Matthew J Fletcher <amimjf at gmail.com
> <mailto:amimjf at gmail.com>> wrote:
> Hi,
> The cpsr thats saved out to r2 is 0x800000df, but is restored back
> to 0x13. Thanks for pointing out that no cpsr change must happen,
> i will check how the rtl22xx_t bsp sets up the cpsr.
> On 25 February 2013 16:52, Sebastian Huber
> <sebastian.huber at embedded-brains.de
> <mailto:sebastian.huber at embedded-brains.de>> wrote:
> On 02/25/2013 05:47 PM, Matthew J Fletcher wrote:
> Hi,
> r2 is 0x13 before the msr, so I guess new_level must have
> been 0.
> On 25 Feb 2013 15:02, "Sebastian Huber"
> <mailto:sebastian.huber at embedded-brains.de>>> wrote:
> On 02/25/2013 03:15 PM, Matthew J Fletcher wrote:
> Sebastian,
> The _Thread_Heir->Registers are ok into the
> _Context_Switch() call, sp
> and lr
> both sensible.
> At the 'mrs r2, cpsr' line sp is 0x40001b2c
> (rubbish) and pc sensible.
> In _restore, after the 'ldmia r1, ...' instruction
> the sp and lr are loaded
> with the correct values from _Thread_Heir->Registers.
> Its the 'msr cpsr, r2' messes up the sp and lr
> Ok, if you load undefined values into the CPSR, then a
> lot of things may
> happen. What is the value of r2 before the msr? It
> should be 0x13.
> Ok, then maybe the mode in the BSP execution context is wrong.
> During _Context_Switch() no mode change must happen. What is
> the CPSR before the msr?
> Phone : +49 89 189 47 41-16 <tel:%2B49%2089%20189%2047%2041-16>
> Fax : +49 89 189 47 41-09 <tel:%2B49%2089%20189%2047%2041-09>
> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne
> des EHUG.
> regards
> Matthew J Fletcher
> regards
> Matthew J Fletcher
URL: <http://lists.rtems.org/pipermail/users/attachments/20130225/3cf754ba/attachment.html>
