ARM (Thumb Mode) _CPU_Context_switch_arm
Matthew J Fletcher
amimjf at gmail.com
Mon Feb 25 19:37:18 UTC 2013
Hi,
I guess it my fault for not 100% copying the rtl22xx BSP into my new
one, i had the cpsr register in a different state at boot_card() time
than the generic ARM context switch code expects. I think that common
binary blob commercial RTOS must do a cpsr read before the first context
switch, rather than rely on a fixed state as i've not encountered this
type of issue before.
On 25 Feb 2013 17:40, "Joel Sherrill" <joel.sherrill at oarcorp.com
<mailto:joel.sherrill at oarcorp.com>> wrote:
On 2/25/2013 11:25 AM, Matthew J Fletcher wrote:
> Sebastain,
> I changed the code so now with the cpsr set as expected before
> main() the context switch occurs fine and we end up in Init().
Is this a generic issue that needs addressing in the RTEMS
git repo? Or something you broke accidentally when making
other changes?
> Thanks for all your help.
A little early for a beer here but it is definitely after 5 for
Sebastian. Good job Sebastian!
--joel
> On 25 February 2013 17:10, Matthew J Fletcher <amimjf at gmail.com
> <mailto:amimjf at gmail.com>> wrote:
> Hi,
> The cpsr thats saved out to r2 is 0x800000df, but is restored
> back to 0x13. Thanks for pointing out that no cpsr change must
> happen, i will check how the rtl22xx_t bsp sets up the cpsr.
> On 25 February 2013 16:52, Sebastian Huber
> <sebastian.huber at embedded-brains.de
> <mailto:sebastian.huber at embedded-brains.de>> wrote:
> On 02/25/2013 05:47 PM, Matthew J Fletcher wrote:
> Hi,
> r2 is 0x13 before the msr, so I guess new_level must
> have been 0.
> On 25 Feb 2013 15:02, "Sebastian Huber"
> <mailto:sebastian.huber at embedded-brains.de>>> wrote:
> On 02/25/2013 03:15 PM, Matthew J Fletcher wrote:
> Sebastian,
> The _Thread_Heir->Registers are ok into the
> _Context_Switch() call, sp
> and lr
> both sensible.
> At the 'mrs r2, cpsr' line sp is 0x40001b2c
> (rubbish) and pc sensible.
> In _restore, after the 'ldmia r1, ...'
> instruction the sp and lr are loaded
> with the correct values from
> _Thread_Heir->Registers.
> Its the 'msr cpsr, r2' messes up the sp and lr
> Ok, if you load undefined values into the CPSR,
> then a lot of things may
> happen. What is the value of r2 before the msr?
> It should be 0x13.
> Ok, then maybe the mode in the BSP execution context is
> wrong. During _Context_Switch() no mode change must
> happen. What is the CPSR before the msr?
> Phone : +49 89 189 47 41-16
> <tel:%2B49%2089%20189%2047%2041-16>
> Fax : +49 89 189 47 41-09
> <tel:%2B49%2089%20189%2047%2041-09>
> Diese Nachricht ist keine geschäftliche Mitteilung im
> Sinne des EHUG.
> regards
> Matthew J Fletcher
> regards
> Matthew J Fletcher
joel.sherrill at OARcorp.com <mailto:joel.sherrill at OARcorp.com> On-Line Applications Research
URL: <http://lists.rtems.org/pipermail/users/attachments/20130225/f5d2bd32/attachment.html>
