Error while building gcc for toolset for RTEMS
manish jain
manish8886 at gmail.com
Fri Feb 8 09:57:40 UTC 2013
Hi All,
Thanks for all your suggestions. The problem was, library cache was not
updated. Now I have successfully built my tool chains for rtems-4.11.
But now I am facing problem in building the RTEMS itself.
I have built my tool set for rtems-4.11 but I am not able to find
RTEMS-4.11 source code in git repository and CVS. All I see is that most
current version is rtems.4.10.2. So I downloaded the code for rtems-4.10.2
and tried to build it.
I am configuring the rtems with following command:
* ../rtems-4.10.2/configure --target=sparc-rtems4.11 --enable-rtemsbsp=sis
--disable-posix --disable-networking --disable-cxx --prefix=/opt/rtems-4.11
And the error I got when I do make all is following:
*configure: error: no acceptable cc found in $PATH
make[2]: *** [sis] Error 1
Actually after getting the error I saw "*
{build-dir/sparc-rtems4.11/c/sis/config.log}*" and problem was that in
PATH: it is not including "/opt/rtems-4.11/bin" but in *
"{build-dir/sparc-rtems4.11/c/config.log}*" the PATH variable is proper.
And my PATH variable is set to : *
/opt/rtems-4.11/bin:/usr/lib/lightdm/lightdm:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games
I have looked the previous mails regarding this problem and most common
cause of this error was PATH variable but I think my PATH variable is
proper. I am not able to figure out why it is happening?
Thanks
Manish
On Thu, Feb 7, 2013 at 10:19 AM, Steven Grunza <sgrunza at ctdi.com> wrote:
> > -----Original Message-----
> > From: rtems-users-bounces at rtems.org [mailto:rtems-users-
> > bounces at rtems.org] On Behalf Of Gedare Bloom
> > Sent: Thursday, February 07, 2013 9:52 AM
> > To: manish jain
> > Cc: RTEMS
> > Subject: Re: Error while building gcc for toolset for RTEMS
> > Aside from the (relatively useful) advice that you may want to try
> > the prepackaged solutions, if you continue with building your own
> > tools you may want to check that mpc/gmp/mpfr are being found. If
> > you built/installed them separately from GCC then you need to add
> > the install point to your library path, e.g. export
> > LD_LIBRARY_PATH=${PREFIX}/lib:${LD_LIBRARY_PATH} for PREFIX equal
> > to where you installed those libraries. If you are using a single-
> > tree build where you link the source for those libraries, then gcc
> > should find them itself. The error you sent is indicative of a
> > missing library.
> If you continue on the path of building your own tools, the command
> "ldconfig -p" is your friend. This command will show you all the
> libraries known and cached. If you installed a library from source and
> don't see it listed, you may need to run "ldconfig" as root to update
> the cache. I've mostly seen this out-of-date ld.so cache problem on
> Fedora/CentOS systems but it can't hurt to check.
URL: <http://lists.rtems.org/pipermail/users/attachments/20130208/90cc5484/attachment-0001.html>
