Error while building gcc for toolset for RTEMS
Fri Feb 8 15:16:37 UTC 2013
4.11 currently refers to the development head, or master. There is no 4.11
branch at the moment. Try the master branch.
The tools are specific to rtems version, so 4.11 tools will not build rtems
4.10.x
-Gedare
On Feb 8, 2013 4:57 AM, "manish jain" <manish8886 at gmail.com> wrote:
> Hi All,
> Thanks for all your suggestions. The problem was, library cache was not
> updated. Now I have successfully built my tool chains for rtems-4.11.
> But now I am facing problem in building the RTEMS itself.
> I have built my tool set for rtems-4.11 but I am not able to find
> RTEMS-4.11 source code in git repository and CVS. All I see is that most
> current version is rtems.4.10.2. So I downloaded the code for rtems-4.10.2
> and tried to build it.
>  I am configuring the rtems with following command:
> * ../rtems-4.10.2/configure --target=sparc-rtems4.11
> --enable-rtemsbsp=sis --disable-posix --disable-networking --disable-cxx
> --prefix=/opt/rtems-4.11
> And the error I got when I do make all is following:
> *configure: error: no acceptable cc found in $PATH
> make[2]: *** [sis] Error 1
> Actually after getting the error I saw  "*
> {build-dir/sparc-rtems4.11/c/sis/config.log}*" and problem was that in
> PATH: it is not including "/opt/rtems-4.11/bin"  but in *
> "{build-dir/sparc-rtems4.11/c/config.log}*" the PATH variable is proper.
> And my PATH variable is set to : *
> /opt/rtems-4.11/bin:/usr/lib/lightdm/lightdm:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games
> I have looked the previous mails regarding this problem and most common
> cause of this error was PATH variable but I think my PATH variable is
> proper. I am not able to figure out why it is happening?
> Thanks
> Manish
> On Thu, Feb 7, 2013 at 10:19 AM, Steven Grunza <sgrunza at ctdi.com> wrote:
>> > -----Original Message-----
>> > From: rtems-users-bounces at rtems.org [mailto:rtems-users-
>> > bounces at rtems.org] On Behalf Of Gedare Bloom
>> > Sent: Thursday, February 07, 2013 9:52 AM
>> > To: manish jain
>> > Cc: RTEMS
>> > Subject: Re: Error while building gcc for toolset for RTEMS
>> > Aside from the (relatively useful) advice that you may want to try
>> > the prepackaged solutions, if you continue with building your own
>> > tools you may want to check that mpc/gmp/mpfr are being found. If
>> > you built/installed them separately from GCC then you need to add
>> > the install point to your library path, e.g. export
>> > LD_LIBRARY_PATH=${PREFIX}/lib:${LD_LIBRARY_PATH} for PREFIX equal
>> > to where you installed those libraries. If you are using a single-
>> > tree build where you link the source for those libraries, then gcc
>> > should find them itself. The error you sent is indicative of a
>> > missing library.
>> If you continue on the path of building your own tools, the command
>> "ldconfig -p" is your friend.  This command will show you all the
>> libraries known and cached.  If you installed a library from source and
>> don't see it listed, you may need to run "ldconfig" as root to update
>> the cache.  I've mostly seen this out-of-date ld.so cache problem on
>> Fedora/CentOS systems but it can't hurt to check.
URL: <http://lists.rtems.org/pipermail/users/attachments/20130208/354d87ca/attachment-0001.html>
